Solved
How Do I Create "Gaps" Between Appointments?
  • October 23, 2023
  • 2 replies
  • 506 views
How Do I Create "Gaps" Between Appointments? For Example, I have two appointments back to back but have some travel time between. Is there a way to give lead time between appointments?
Best answer by Dustin53526
Never Mind, I figured it out. It’s in the scheduling settings under “Buffer Time”.
Dustin53526AuthorAnswer
Kelsi
CalPal Emeritus
October 23, 2023
@Dustin53526 so glad you were able to figure out buffers!
Here is a help center article about using buffers, in case it helps as well!
Let us know if you run into issues!
Kelsi - Calendly Community
