Mar 6, 2024 9:36 PM UTC
Embed Parameter + Branding Issues
Hey @Kelsi at Calendly, I am not seeing “a parameter branding that should have the value false in order to turn off the branding” in the popup widget code. This is what I see. What am I missing? I have already toggled branding off, but it’s still visible on the website.
Michael G
Employee
Employee
Apr 2, 2024 2:24 PM UTC
Hi @Corey21011,
Sorry you are running into issues disabling branding on your embed!
The screenshot you have provided appears to be for an inline embed, rather than the pop-up widget.
In our help center article, Embed options overview, you can see an overview of the differences.
Lets take a look at this example code:
<!-- Calendly badge widget begin -->
<script src="https://assets.calendly.com/assets/external/widget.js" type="text/javascript" async></script>
<script type="text/javascript">window.onload = function() { Calendly.initBadgeWidget({ url: 'https://calendly.com/YOUR_URL_HERE', text: 'Schedule time with me', color: '#0069ff', textColor: '#ffffff', branding: false }); }</script>
<!-- Calendly badge widget end -->
Notice at the very end, before the closing script tag, there is a value of “branding: false”
You should see this in your existing code as “true”, and all you should need to do is change that value!
Hope this helps!
