Apr 8, 2025 2:12 PM UTC
Token of API V1 does not work with API V2
Hi,
I’m using Flutterflow and tested on postman.
Here is the API call which does work well
https://api.calendly.com/users/c87babc0-4bb4-4659-9ed5-f4ac3f6c6202/
And here is the API V2 call which does not work
https://api.calendly.com/scheduled_events?count=5&page_token=MY_TOKEN&user=https://api.calendly.com/users/c87babc0-4bb4-4659-9ed5-f4ac3f6c6202
I made the test with Postman and Reqbin, still the same result
  "title": "Unauthenticated",
  "message": "The access token is invalid"
Maybe, I missed something or I misunderstanding but I’m looking for why I get this error message.
Thank you  for your help
PS : I’m under 14days trial before starting the paid version. WOuld it be a limitation for the free version ?
Tems.hkAuthor
Apr 8, 2025 3:11 PM UTC
Solution Found :
Needed to define : Authorization: Bearer and not page_token as parameter
Solved
