Nov 14, 2023 6:50 PM UTC
Solved
Why does the webhook callback signing key change with every call as opposed to using mine?
I successfully used the webhook callback API with signing_key verification a few days ago. But now, for some reason, the signing key changes with every callback making me reject the call.
What could possibly be the cause? I did follow the docs @ https://calendly.stoplight.io/docs/api-docs/c1ddc06ce1f1b-create-webhook-subscription
Below is my successful webhook I created:
    "collection": [
            "callback_url": "https://TO_SOME_PLACE/",
            "created_at": "2023-11-14T18:45:52.610226Z",
            "creator": "https://api.calendly.com/users/USER_ID",
            "events": [
                "invitee.created",
                "invitee.canceled",
                "invitee_no_show.created"
            "organization": "https://api.calendly.com/organizations/ORG_ID",
            "retry_started_at": null,
            "scope": "user",
            "state": "active",
            "updated_at": "2023-11-14T18:45:52.610226Z",
            "uri": "https://api.calendly.com/webhook_subscriptions/SUB_ID",
            "user": "https://api.calendly.com/users/USE_ID"
Thank you in advance
anolsonAnswer
Employee
Nov 14, 2023 7:31 PM UTC
Hey Andreas!
We don’t send the signing key with each webhook payload. What we send instead is signature that’s computed by:
  • Combining a timestamp and the request body
  • Then generating a HMAC digest with the webhook signing key
You’ll need to do this same computation on your end to verify each payload. We have a few different code examples here:
https://developer.calendly.com/api-docs/4c305798a61d3-webhook-signatures
anolsonAnswer
Employee
Hey Andreas!
AndreasBAuthor
Nov 14, 2023 11:47 PM UTC
I somewhat skipped the code examples and simply assumed it’s a simple comparison but what you describe and actually do makes much more sense of course. I changed the code and it works as expected now. My earlier success stemmed from internal testing where I artificially fabricated the headers, thereby cheating.
Again, thank you for the speedy reply. Everything is now fully integrated as we’d like and works as expected.
-Andreas
P.S. For those in need of a Python way to implement the HMAC digest verification, here it is:
# Assuming you got headers in dict form and body as byte
# Get your assigned signing key
webhook_signing_key = os.getenv("WEBHOOK_SIGNING_KEY")
# Split signature header by time and signature
signature_header = headers['Calendly-Webhook-Signature'].split(',')
t = signature_header[0].split('=')[1]
signature = signature_header[1].split('=')[1]
# Construct payload to sign
payload = t + '.' + body.decode('UTF-8')
# Generate signature with secret key
hexdigest = hmac.new(webhook_signing_key.encode('UTF-8'), payload.encode('UTF-8'), hashlib.sha256).hexdigest()
# Verify signatures
if hexdigest != signature:
    raise Exception(‘Invalid Signature’)
Employee
Nov 15, 2023 2:15 PM UTC
That’s great to hear!
