Jun 2, 2025 11:54 AM UTC
Calendly + JIRA Integration (formatting date/time) - Need Help!
We just migrated to Calendly API v2 and are having issues with formatting the date/time fields.
In particular, I’m using the start_time api field. There is no more “pretty” version of the start_time api field, so we need to format it in JIRA automation.
I noticed, we get the date/time value in the start_time field as “2025-06-25T05:00:00.000000Z” (for example). However, in the JIRA documentation, JIRA is expecting the date/time field as “2020-08-18T02:40:37.0+0000” (for example).
Because of this, the smart value format operations in JIRA automation do not recognize the date/time format therefore will not work.
Has anyone found a solution to this issue?
Employee
Jul 1, 2025 7:16 PM UTC
Thanks for reaching out about formatting the start_time from the Calendly API for use in Jira Automation!
You're correct that the Calendly API v2 returns timestamps in ISO 8601 format with microseconds and a Z to indicate UTC—for example:
Jira, on the other hand, expects timestamps in a slightly different ISO 8601 format without microseconds and with an explicit UTC offset, like:
To make the Calendly start_time compatible, you'll need to reformat it before passing it into your Jira Automation logic. Here's a general approach you can use:
🛠 Option 1: Use Jira Smart Value Formatting
If you're passing the raw value into Jira via webhook, you can try formatting the value using Jira's Smart Value date functions, like this:
{{webhookData.start_time.convertToDate.format("yyyy-MM-dd'T'HH:mm:ss.SZ")}}
Note: Jira may not support microseconds, so you might need to trim .000000Z from the end of the start_time string using string manipulation before formatting.
🛠 Option 2: Pre-process the timestamp externally
If Jira Smart Values can't handle the conversion directly, consider passing the timestamp through a small middleware (e.g. a webhook, Zapier, or AWS Lambda) that:
  1. Converts 2025-06-25T05:00:00.000000Z → 2025-06-25T05:00:00.0+0000
  2. Sends the formatted timestamp to Jira Automation in the format it expects
While implementing this logic on your end is out of scope for Calendly Support, feel free to reach out to our team if you have questions—we're here to support you and will help to the best of our ability!
You can contact us via live chat (look for the blue chat bubble in the lower right when logged into a paid Calendly account), or email us at support@calendly.com.
