Embed code blank
I’m trying to put a basic Inline Embed into my code. When I put it in though it just shows a large blank space and I’m not sure why.
<!-- Calendly inline widget begin -->
<div class="calendly-inline-widget" data-url="https://calendly.com/maximuscarere/30min" style="min-width:320px;height:700px;"></div>
<script type="text/javascript" src="https://assets.calendly.com/assets/external/widget.js" async></script>
<!-- Calendly inline widget end -->
Michael G
Employee
Employee
April 2, 2024
Hey there @Max05223 - thanks for your topic!
Sorry you are running into issues with your embed. We have easy to follow articles in our Help Center that go over the step-by-step how to embed in different site builders!
Here is the first article you should check out. Please notice some of the callouts in this Help Center article, such as the below:
Select your website provider to learn more about the embed options available for your website.
I hope this helps!
If you are still running into issues, can you share with us the website provider you are using along with how you have implemented your code? Thanks!
