Jun 18, 2025 1:30 AM UTC
Help!. I am not receiving https://calendly.com/scheduled_events/
After a Calendly booking via Typeform, I only receive the invitee ID, but I need the event UUID for API purposes. How can I get the event UUID?
Jun 18, 2025 1:04 PM UTC
​@prajwol46456 - is the invitee id in a URI format (example: https://api.calendly.com/scheduled_events/123/invitees/123)?  If so, you can extract the event URI by removing /invitees/ID
Jun 18, 2025 10:13 PM UTC
No its is not
I am getting the https://calendly.com/ /   /invitees/123
I want the scheduled events so I can parse it
