Nov 4, 2024 7:47 PM UTC
How do I dynamically capture UTMs on an embedded Calendly submission?
Hi all, I hope someone can help me with this.
Issue:
I’ve embedded a Calendly widget into my website.
I’ve tried following along with the documentation to dynamically add UTM parameters to the data-url (as the documentation says) and reinitialise the Calendly widget (along with trying a range of other things): https://help.calendly.com/hc/en-us/articles/4406950779799-How-to-source-track-your-Calendly-embed-with-UTM-parameters#h_01HBEHS384CGRJB9RHQH0T4A8Y
Still whenever I submit the widget, no UTMs are passed through.
I’ve tried adding them to the data-url, using prefill, and reinitialising the widget after adding them.
Use Case:
I need to be able to track the source and medium of sessions (especially who come from campaigns) when a user fills out the Calendly widget on an embedded calendar on my website.
It seems everything (all integrations and help pages) is geared around people booking on a Calendly page and not via an embedded calendar on a website.
Surely there is a solution to this?
It needs to be dynamic and the values need to persist for more than the first landing page. I have cookies storing the UTMs from the initial landing page URL but there seems to be no way to grab them from from the cookie and add them to the Calendly submission without reloading the page and adding them back to the URL if the widget is found, which is entirely gross and not usable.
Any help really appreciated. Otherwise I will have to start the search for a similar app in the hope another one does this :(
Thanks in advance for any help!
Clifton
Employee
Employee
Nov 4, 2024 8:52 PM UTC
The widget uses a static UTM thats set at initialization, so you would have to use Javascript to update it before the page initializes (or reinitializes) the widget from your cookie, essentially replacing it each time you have a new UTM.
  1. On the first website visit, capture any UTM parameters from the browser address bar and store the UTM values in the browser cookies. (Sounds like you have done this!)
  2. Whenever the UTM parameter changes in the browser address bar, update the browser cookies with the new UTM parameter values.
  3. On every page where Calendly is embedded, retrieve the UTM parameters from the browser cookies and place them in the Calendly initialization function. (You would need to replace the UTM set for the widget in widgets original initialization call, and reinitialize it with that new value, so that it submits whatever UTM that is included in the url you navigated to the page from)
abcd51401Author
Nov 5, 2024 9:40 AM UTC
Thanks so much Clifton for your quick response!
This is what I have done exactly :)
Here is my script which I’m firing via GTM on all pages:
<script>
setTimeout(function() {
console.log("Calendly UTM script started - delayed execution");
// Function to get the value of a cookie by name
function getCookie(name) {
var value = "; " + document.cookie;
var parts = value.split("; " + name + "=");
if (parts.length === 2) {
return parts.pop().split(";").shift();
return null;
// Function to parse UTM parameters from a URL
function getUTMParams(url) {
try {
// Prepend protocol if missing
if (url.indexOf('http://') !== 0 && url.indexOf('https://') !== 0) {
url = 'https://' + url;
var urlParams = new URL(url).searchParams;
return {
utm_source: urlParams.get('utm_source'),
utm_campaign: urlParams.get('utm_campaign'),
utm_medium: urlParams.get('utm_medium'),
utm_content: urlParams.get('utm_content'),
utm_term: urlParams.get('utm_term')
} catch (error) {
console.error("Error parsing UTM parameters from URL:", error);
return {};
try {
// 1. Check for a Calendly embed on the page
var calendlyEmbed = document.querySelector('.calendly-inline-widget');
if (!calendlyEmbed) {
console.warn("No Calendly embed found on the page.");
return; // Exit if no Calendly embed is found
console.log("Calendly embed found on the page.");
// 2. Get the value of the `__gtm_campaign_url` cookie
var campaignUrl = getCookie('__gtm_campaign_url');
if (!campaignUrl) {
console.warn("No campaign URL found in the '__gtm_campaign_url' cookie.");
return; // Exit if no campaign URL found in cookie
console.log("Campaign URL found:", campaignUrl);
// Decode the campaign URL in case it is URL-encoded
var decodedUrl = decodeURIComponent(campaignUrl);
// 3. Parse UTM parameters from the decoded campaign URL
var utmParams = getUTMParams(decodedUrl);
console.log("Parsed UTM parameters:", utmParams);
// 4. Dynamically set the UTM parameters to Calendly
var calendlyUrl = new URL(calendlyEmbed.getAttribute('data-url'));
for (var key in utmParams) {
if (utmParams.hasOwnProperty(key) && utmParams[key]) {
calendlyUrl.searchParams.set(key, utmParams[key]);
// Update Calendly URL with UTM parameters
calendlyEmbed.setAttribute('data-url', calendlyUrl.toString());
console.log("Updated Calendly URL with UTM parameters:", calendlyUrl.toString());
// Reinitialize Calendly embed to apply new URL with UTM parameters
Calendly.initInlineWidget({
url: calendlyUrl.toString(),
parentElement: calendlyEmbed.parentElement
console.log("Calendly widget reinitialized with updated URL.");
} catch (error) {
console.error("An error occurred while setting UTM parameters for Calendly:", error);
}, 1000); // Delay of 1 second to allow page elements to load
</script>
abcd51401Author
Nov 6, 2024 1:51 PM UTC
@Clifton just FYI which I didn’t make clear in my previous message. This does not work.
Can you help?
Thanks
Clifton
Employee
Employee
Nov 6, 2024 7:33 PM UTC
I’m not sure I 100% understand your workflow, my only suggestion is to try setting the UTM information from the cookie, in the utm argument, when you call Calendly.initInlineWidget
url: 'https://calendly.com/YOUR_LINK/30min',
utm: {
utmCampaign: "[Information stored in Cookie]",
utmSource: "[Information stored in Cookie]",
utmMedium: "[Information stored in Cookie]",
utmContent: "[Information stored in Cookie]",
utmTerm: "[Information stored in Cookie]"
I believe this is what will be sent when the booking happens
