Nov 28, 2023 6:33 PM UTC
Solved
Issues with embed
Hello.
Just recently, the embed instructions noted here have stopped working:
https://help.calendly.com/hc/en-us/articles/223147027?tab=advanced#3
Using the invocation code:
Calendly.initInlineWidget({
                url: 'https://calendly.com/d/FORMIDREMOVED?hide_gdpr_banner=1',
                parentElement: document.getElementById('calendly-modal-body'),
                prefill: {}
Spawns a request to Calendly that ultimately returns this response
cf-cache-status: DYNAMIC
cf-ray: 82d4ad0a0b103705-YYZ
Content-Encoding: br
Content-Type: text/html; charset=utf-8
Date: Tue, 28 Nov 2023 18:29:21 GMT
Last-Modified: Tue, 28 Nov 2023 15:50:04 GMT
Server: cloudflare
Strict-Transport-Security: max-age=31536000; includeSubDomains; preload
Vary: Accept-Encoding, Origin
Via: 1.1 192b5dfe0d3306c6761973a7786a01d4.cloudfront.net (CloudFront)
x-amz-cf-id: qnDkzkCQ-DxfUc_z4Pp1jZA24f5UoczK1oqvza1rvhS0u98DWrPW4A==
x-amz-cf-pop: YUL62-C2
x-amz-version-id: EVin17i.0_5u4mmzATuQGsDtuQywgDL1
x-cache: Hit from cloudfront
X-Content-Type-Options: nosniff
X-Frame-Options: DENY
The X-Frame-Options: DENY is the kicker, since the Calendly.initInlineWidget call spawns within an iFrame.
In other words, the javascript says: load _this_ in an iFrame
The iframe body request says: no iFrames allowed.
New bug?
marion-calendly
Employee
Nov 28, 2023 8:55 PM UTC
Hi @LemonadeLXP !
We experienced an incident earlier that affected routing forms (see our Status page) which would have resulted in the embed code loading a page that could not be displayed in an iframe. Based on the timing of your post, I think you may have been impacted by this.
If you’re still seeing the same result, I would also recommend checking that the link you have passed to the code is valid (e.g. by loading it in your browser directly). Our 404 page also has X-Frame-Options: DENY so this is the most common reason for seeing that in our embed.
marion-calendly
Employee
Employee
Hi @LemonadeLXP !
Nov 28, 2023 9:09 PM UTC
Thank you for confirming.
Kelsi
CalPal Emeritus
Nov 28, 2023 9:27 PM UTC
We are so glad this helped! Let us know if you have further issues. Have a great day!
Kelsi - Calendly Community
