Jul 22, 2024 11:30 AM UTC
Logging out with Iauth2.0
in my product, I have integrated Calendly using oauth2.0.
When user logged in, it stores cookie inside their domain calendly.com.
The problem is when user sign out and again sign in because of those cookies already store, it does not ask for credentials and logged in with previous account automatically.
At the time of logging out, also invoked revoke token endpoint API provided by Calendly.
Employee
Jul 22, 2024 12:55 PM UTC
Calendly does not manage a logged-in / logged-out state via oauth. Each request to calendly is authenticated via a unique oauth token. Each time you make a request to Calendly (whether or not a user is logged into your app) you will need to use a refresh token to acquire an access token and then use that access token to make a request. You also do not need to revoke tokens when a user logs out of your account. Access tokens are automatically revoked when they are used.
Jul 22, 2024 1:07 PM UTC
I do have revoked token when user does logout. Let me share your relevant codebase in C#.
async Task<BaseOutput<RevokeToken>> RevokeClientTokenRequestMethod(FormUrlEncodedContent content)
HttpRequestMessage httpRequest = new(HttpMethod.Post, $"{UrlType.OAuth}{UrlType.RevokeToken}")
Content = content
HttpResponseMessage response = await _httpClient.SendAsync(httpRequest);
string reponseContent = await response.Content.ReadAsStringAsync();
if (response.StatusCode is not HttpStatusCode.OK)
AuthError error = Helper.DeserializeObject<AuthError>(reponseContent, _options);
HandleError(error);
RevokeToken revokeToken = Helper.DeserializeObject<RevokeToken>(reponseContent, _options);
return BaseOutput<RevokeToken>.GetOutput(revokeToken);
private async Task<T> ExecuteRequest<T>(Func<Task<T>> action)
_httpClient.DefaultRequestHeaders.Add(
HeaderTypeKey.ContentType,
HeaderTypeValue.ApplicationXWwwFormUrlEncoded);
return await action();
 When user connect with my application using OAuth2.0, it does store these cookies inside their calendly.com domain.
Cookies stored at calendly.com
Hence, at the time of logging out event I revoke token of user (both access and refresh) it does again login directly.
