Oct 25, 2025 9:20 AM UTC
Multi use coupon codes
Hi all,
I have two services and want to use the same 20% off coupon code for both. I see this is not yet available to want to start a thread to build interest to have this feature added.
Surely this is only a quick dev fix to allow duplicates???
If it helps 😁
{removed by moderator}
Apr 13, 2026 11:37 AM UTC
Hi, were you able to fix it? I need it too
Aug 16, 2026 1:45 PM UTC
Surely, we can all benefit from this? I cannot be using 20 different coupon codes for the same type of discount…
