Aug 12, 2024 3:46 AM UTC
Webhook not working
I have an integration with an app I’m developing for scheduling meetings. My app checks the Calendly API and verifies the calendly subscription still exists everytime when it starts.
I’m running NGROK to forward requests locally currently with the subscription and I can no longer see requests from Calendly. I confirmed the subscription is still there. I just tested another webhook for an esignature API I also have setup and it’s working and forwarding. The calendly one is broken and doesn’t forward (invitee.created in this case).
It was working before, I have no network issues so I assume this is a Calendly problem. I can see the token shows last access date so auth/connect is fine. I am just not receiving payloads anymore. I last saw this working a few days ago.
Adam40862Author
Aug 13, 2024 1:02 AM UTC
Turns out the webhook was disabled because of Calendly sending payloads which weren’t responded to. I modified my app to recreate the webhook everytime. I thought most API providers only try to send a payload 2 or 3 times and then stop per request but calendly will disable it based on some threshold and you won’t know about it unless you check.
Nov 14, 2024 9:32 PM UTC
It looks like if there’s an error with the webhook, it will keep retrying for 24 hours. But if it doesn’t get a response, the webhook becomes disabled, and you have to recreate it.
I’m posting the link to where I found this info Calendly webhook errors
