May 10, 2024 3:36 AM UTC
Whether webhook integration allows JWT authorization with Power apps?
I am trying to listen to Calendly events using Power Automate but we cannot expose the url directly to the web hook registration, what different methods can be used to call the API?
Whether Calendly allows JWT token integration while registration of a web hook subscription?
tcampb
Employee
Employee
May 10, 2024 5:31 PM UTC
@amit88 - when creating a webhook subscription you can provide a “signing_key” value. This is a unique secret key shared between your application and Calendly.
This will allow you to verify the authenticity of the webhook by checking the webhook signature. More information can be found here - https://developer.calendly.com/api-docs/4c305798a61d3-webhook-signatures
Would verifying the webhook signature allow your team to expose the webhook url?
