Booking page options *required* location question.
  • March 5, 2024
  • 7 replies
  • 345 views
How do I remove the *required* location question from Booking page options?
Kelsi
CalPal Emeritus
March 5, 2024
Hey there @A73485 - great question! Firstly, check out our New User Guide - it’ll def prove helpful as you get used to the platform!
At this time, location will always be required both in your event type settings and as a display on the public booking page. There is no way to remove the location field at this time.
I’m sorry for the inconvenience!
I hope this helps!
Kelsi - Calendly Community
A73485Author
That’s unfortunate as my radio button question options are Face to Face at your home address / Remote over the internet / by phone. I would be great if I had the option to switch of this unnecessary input box.
Kelsi
CalPal Emeritus
March 5, 2024
Is the issue that you are having that you have multiple options and only want to offer one? If so - you can do that! Head into your event type settings > click “event type summary” > under “location” click the ‘x’ next to the location options you’d like to remove! Then, click “save and close” at the bottom of the editor. Boom, only one location option!
Click the “x” next to the location(s) you would like to remove
If this is not the issue at hand - I apologize!
A73485Author
Can I put the removal or the option to remove this as a software update option going forward?
Kelsi
CalPal Emeritus
March 12, 2024
I will certainly make sure that your feedback is included in our monthly report for our product team! =)
A73485Author
Any joy?
Kelsi
CalPal Emeritus
April 4, 2024
Any joy?
Hey there - thanks for following up! I wish I could give you any information regarding if or when this might be an update implemented - but I can’t! In the meantime we appreciate your understanding. You can always track updates via our product update page!
