Calendars not connected, when they are
I look after a group of people, that use Calendly for scheduling. It seems recently a bunch are showing as ‘hasn’t connected a calendar’, however their calendars are in fact connected and have been for some years. When I log in to check the user group there are several that show this - has something changed recently on the Calendly side to trigger this? Noting this is not the normal error response, when a calendar has disconnected. How do I fix this, and stop it happening again?
Hi ​@JenGriff - Thanks for reaching out on this.
For something like this, I’d recommend reaching out to our support team on this so they can dig into your specific account a bit further!
You can either email us at support@calendly.com or chat with us directly from your account for quicker assistance. Our support team will help dig into the issue from there!
JenGriffAuthor
Great, thank you. Will do that
