Calender sync why doesn't it work?
  • August 22, 2024
  • 3 replies
  • 94 views
If I syncronise the calendly calender with antother, wouldn’t it syncronise?
If I’m occupied in one agenda, wouldn it be unavailable in de calendly agenda??
    Sean Marlin
    Hi Marieke70743!
    Calendly is a product that sits on top of your calendar. It will add meetings to your calendar if there is availability. To be clear, you are not creating a separate calendar with Calendly. It is simply a booking tool that automates scheduling through your existing digital calendar.
    How does Calendly work? (Everything you need to know to start scheduling)
    Well, that is weird because I see them next to each other, not connected….
    I have private meetings, but next to the meeting, there is availability to make an appointment with calendly…
    What did I do wrong?
    jillian
    Hi @Marieke70743!
    There’s a few possibilities, but the most likely one is that your events on your calendar aren’t marked as ‘busy’ or they’re on a sub-calendar that isn’t being checked for conflicts. Either way, I’d really recommend giving the Troubleshooting Availability tool a try as it will help you identify the reason behind times that either should or should not be available. More on that here:
