Calendly shows me completely busy every Tuesday when I am not.
  • September 5, 2024
  • 3 replies
  • 133 views
Calendly shows me completely busy every Tuesday when I am not and have nothing on my calendar that would cause a problem.
This issue only occurs on Tuesday's. Every other day is fine.  I have cleared and reset all the settings I can find. I've created a new event type. I have looked at all of the help information and tutorials. Nothing comes close to helping me resolve the issue.
 If you want me to go back to help, tutorials, video's, articles, etc. then tell me exactly where to go. I've spent more than an hour trying to find my answer by searching blindly. I'm not going through another  wild pig hunt. I’ll just go find another scheduling platform.
jillian
Hi @Chris61766,
I’m 99% sure you likely have some sort of all-day event on your native calendar (Google Calendar, Outlook Calendar, etc.) that is causing your day to appear blocked off to Calendly - something I’ve done to myself many times! If there is something on that day, it needs to be marked as ‘Free’ in order for Calendly to not see the day as unavailable.
For situations like this, the absolute most helpful resource is our Troubleshooting Availability Tool. More on that here:
Jillian, I have searched my native calendar and can’t find anything that would indicate an all day conflict.  Is there another way that I can find it?
jillian
Hmm. Any chance you have something on a sub-calendar? Also, while I’m sure you have checked this, double check all day events and any blocks you thought were marked as ‘Free’. If you’re using Google Calendar, a lot of the special time blocks (focus, OOO, etc.) show up as busy.
I’m trying to think of other weird possible native calendar issues like missing events, permissions, etc. and coming up a bit empty.
