Jan 9, 2025 1:15 PM UTC
Calendly Stripe Integration: Test Card Declined Despite Being in Test Mode
Hi everyone,
I'm experiencing an issue with the Stripe-Calendly integration for a video consultation booking system with payment.
Situation:
  • My Stripe account is definitely in TEST mode (purple banner visible on dashboard)
  • I have set up the integration between Calendly and Stripe
  • I'm trying to test a booking using the Stripe test card (4242 4242 4242 4242)
Issue: When validating the payment on Calendly, I get the following error: "Your card was declined. Your request was made in live mode, but used a known test card."
This error is contradictory since I'm certain I'm in test mode on Stripe. I've already tried disconnecting/reconnecting the integration but the problem persists.
Has anyone encountered this issue before or have any suggestions on how to fix it?
Thanks in advance for your help!
Jan 9, 2025 2:05 PM UTC
Hi ​@jeanjean - Thanks for reaching out!
There isn't a test payment mode on Calendly unfortunately. So the test payment will need to be made with a dollar payment for testing. Based on the error, it looks like you are in live mode, but using a test card from Stripe. So using an actual card to test the functionality would be needed. I suggest setting the payment for the booking to $1 to test it, then changing it back when sending it to clients.
