Solved
Does Calendly prevent double bookings on $12 a month plan with two different appt options?
  • June 24, 2024
  • 1 reply
  • 368 views
I have two different appointment options for two different types of clients. Does Calendly prevent double booking if a Client A books an appointment and then Client B tries to book appointment at the same time?
Best answer by Kelsi
Hey there @Matt23021 -- great question.
The answer is yes! Calendly will always prevent double bookings regardless of what plan you are on.
When an invitee books with you, that date/time will be blocked off on all of your Calendly event types regardless of how many you have. This is automatic and one of the core features of Calendly.
I hope this helps!
Kelsi
KelsiAnswer
CalPal Emeritus
June 25, 2024
I hope this helps!
Kelsi - Calendly Community
