Apr 7, 2025 6:31 PM UTC
Issue with remove Location Variable
I need to remove the location from my appointments because I now only offer online sessions. At the moment, I’m not able to delete or remove the location myself.
Can an admin do this for me? Or is there another way to make this change?
I have 23 different event types – so I’d really appreciate a convenient solution.
Apr 7, 2025 6:34 PM UTC
Hi ​@Saskia00314 - Thanks for reaching out!
At this time, there is no way to action this change across your event types all at once, this would need to be done manually through your account - My apologies!
However, this is something thats been requested before, I can pass this off to our product team to see if this is something we can add in the future!
Let me know if you have any other questions
Apr 7, 2025 6:48 PM UTC
Thanks again for your reply.
Just to be clear:
Are you saying I can’t edit the location in existing events at all?
Does that mean I would need to recreate all 23 event types from scratch?
That would be extremely time-consuming.
Is there really no other way to simply remove the location?
I’d really appreciate a practical solution here, even a workaround.
Thanks for looking into this again.
Apr 7, 2025 6:52 PM UTC
Hi ​@Saskia00314 - You should be able to just change the location within the editor. If you edit the event, then select Event Details, you’ll see each location option here:
If you select the ‘X’, it will remove the option from the event, without having to recreate anything.
If you run into any issues here, let me know!
