Dec 17, 2024 2:59 AM UTC
Not Able to view my intermitted schedule.
When I create an event and I schedule myself for only 4 hours. I get this error  and I don’t get the Boxes for the recipient to choose there time.
Dec 17, 2024 12:56 PM UTC
Hey ​@StarTek - Thanks for reaching out and including those screenshots!
Taking a look at your availability settings, it looks like the Date-Range is at odds with each other:
Currently, this is set to allow invitees to only be able to schedule one day into the future, however, its also set to only allow invitees to schedule with a two day notice. Personally, I would adjust it to allow at least a week into the future to give some extra time to allow your invitees to schedule with you.
Once you adjust this, let me know if it works! Additionally, you can also use the Troubleshoot option on your booking page to see why specific dates won’t appear:
StarTekAuthor
Dec 17, 2024 3:52 PM UTC
I tried the troubleshoot LOL did not help . I am an IT guy I went threw it for an hour trying to figure out my issue. Thanks for assisting  Your suggestion helped out a little it just left out ½ the day . Can you make some suggestions to view the rest of the day from 1pm to 4pm  Thanks
Dec 17, 2024 3:58 PM UTC
Since those settings look correct, the next thing I would check is your connected Calendar, to see if any of those days have an event posted during those hours. By default, Calendly will block off time if it detects any Busy events in your calendar. You can see whats connected by going to your calendar settings page here: https://calendly.com/app/availability/calendar_settings
Could you see if there are any events posted at those times?
StarTekAuthor
Dec 17, 2024 4:16 PM UTC
That worked Thanks Learning your product here LOL
StarTekAuthor
Dec 17, 2024 4:22 PM UTC
Quick question ? Do I get an email automatic regarding the person setting up a meeting with me ?
Dec 17, 2024 4:34 PM UTC
Great to hear! Yes thats correct, once a user schedules, you’ll receive an email notification about the event. Additionally, you’ll get a calendar event added automatically for your booked times.
