offering two separate date options for an event without using date range
hi is it possible to select two separate dates for attendees to choose from without using date range. so only offering Monday 10th June and Tuesday 05th May without all the dates in between. thanks! 🤩
Hi ​@Andrew17630 - Thanks for reaching out!
In this case, you can set Create date-specific hours for your events. This allows you to set specific days that you’d like to be available :
If you’re setting date-specific hours, you’ll want to be sure to remove any weekly hours as well. This ensures additional times won’t appear either.
