Kelsi
KelsiAnswer
CalPal Emeritus
June 11, 2024
Hey there @Steve20320 - sorry for the confusion, but I am so glad you posted!
So, when you head to “meetings” > “upcoming” you will see the following, in your case:
  • One timezone (large)
  • Second timezone (smaller)
  • Invitee timezone (if you click “invitee details” next to each booked invitee, you will see their timezone listed there)
The larger timezone you see in your screenshot is the timezone in which you set up your event type/the timezone Calendly sees that booking as taking place in. The smaller timezone underneath it is the secondary timezone to you -- because you (likely) set your account settings to a different timezone than the event takes place in.
This is to help you differentiate if you are traveling/in a different timezone than your event type is set up to take place in.
I hope this helps!
If you are still confused, check out the following:
  • head into your event type settings and look at your availability section to see what timezone you set up the event in
  • head into your account settings to see what timezone you set up your account in
Let us know if you get stuck!
Check out this article, too:
Kelsi - Calendly Community
Kelsi
KelsiAnswer
CalPal Emeritus
June 11, 2024
I hope this helps!
Thank you so much for clarifying @Kelsi at Calendly!
Kelsi
CalPal Emeritus
June 20, 2024
You are so very welcome @Steve20320 -- happy to help! 😄
