Solved
Setting availability going forward
It’s tax season, and will be until April 15th. I have Saturday availability until then, but post-season I am closed on Saturday. Is there a way to schedule Saturdays starting on April 19th as being unavailable without changing all of the prior Saturdays, without having to change them one by one?
Thanks, David - that was exactly what I needed!
Hi ​@greglynchcpa!
Thanks for reaching out.
I think the best way to make this change is through the Availability tab by using Date-specific hours. This would allow you to select all Saturday's at one time, all the way up until April.
This would allow for bookings to happen on Saturdays, only on the days you set. Then just make sure to remove the Weekly Hours option:
greglynchcpaAuthorAnswer
