Travailler sur deux lieu différents
  • February 21, 2024
  • 1 reply
  • 264 views
Bonjour
Je vais ouvrir un autre cabinet de consultation à une autre adresse. Les clients auront donc le choix entre deux adresse. Mais je ne sais pas comment faire sur Calendly.
Est-ce que cela est possible ?
    Kelsi
    CalPal Emeritus
    February 21, 2024
    Hey there @Myriam66608 - great question, and thanks for your topic! Firstly, check out our New User Guide - it’ll def prove helpful as you get used to the platform! Check out our Company Admin Guide, too!
    To answer your question - yes! Your best bet is going to be the following:
    Firstly, add your desired team members to your account from your Admin Management page. Then, you can set up a team page. Your team page will have all of your events specific to that team: round robin or collective. You can also use your team page as the landing zone for your second address. This will make it possible for your events at both addresses to overlap/be booked simultaneously (overlapping events cannot be booked on a single user account).
    Round Robin events will allow your invitees to book an appointment at any time at least one assigned team member is available. Collective events allow invitees to book an appointment when all assigned team members are available.
    If you'd like a more thorough breakdown of the team features, check out this recording that walks through the basics of using Calendly with your team.
    You will also want to check out this article:
    I hope this helps!
    Kelsi - Calendly Community
