Dec 3, 2024 10:25 PM UTC
Trouble setting up registration for workshop
I’m scheduling a two hour workshop for February 2, 2025. When I set up the event I created date-specific hours from 11 - 1. However, when I preview the event the calendar is showing no available dates in February. What should I do?
Dec 4, 2024 1:37 PM UTC
Hi ​@Vickie04102! Thanks for reaching out about this.
In this case, the best way to look into any unavailability is by using Calendlys Troubleshooting tool! To utilize this, go to your booking page, and select the Troubleshoot button, then select any dates that should be available:
A related code will appear for those specific days, based on that code, you can follow the steps in this article to resolve it: How to use Calendly's Troubleshoot Tool
