Two Accounts Running Simultaneously?
  • June 11, 2024
  • 1 reply
  • 152 views
Is it possible to have two different Calendly accounts runnning simultaneously that book appointments on the same Google calendar?
Kelsi
CalPal Emeritus
June 11, 2024
Hey there @Peter50177 -- great question!
Yes -- if you have two separate Calendly accounts and you have set up the same Google Calendar as the “add to” calendar in both of those accounts, Calendly will push bookings from both accounts to the same Google Calendar.
I hope this helps!
Kelsi - Calendly Community
