Jan 8, 2025 3:14 PM UTC
What happens when I add a calendar block (creating a conflict) *after* clients have booked?
Hi all,
A colleague had a full slate of appointments, and subsequently added an unrelated, all-day block  (indicating a multi-week commitment). What happened to the clients who had scheduled appointments? Did they receive cancelation messages?
Thanks!
    Jan 8, 2025 3:33 PM UTC
    Hi ​@People66572 - Thanks for reaching out!
    Adding an event that overlaps other events in the Calendar would not automatically remove the overlapped events. However, if they went through and deleted or declined them in their Calendar, Calendly would cancel the events and send a notice to the invitee as long as they have Sync Cancellations enabled on their Calendar Connections page:
    They can always check their meetings page to ensure they were cancelled fully.
    Jan 8, 2025 3:44 PM UTC
    Thank you! I serve as an admin for a group of providers, so I don’t have direct visibility into their calendars. Is it possible for an appt to show up on a client’s calendar if we no longer see it in the provider’s list of upcoming appointments (the view below)?
    Jan 8, 2025 8:20 PM UTC
    Got it! In this case, if the event does not show up in your upcoming appointments, that meeting is most likely cancelled. So depending if the event was declined or deleted, the same would show on the clients calendar. This is more handled on the calendar providers side as we mostly just handle the cancellation notification. 🙂
