Dec 10, 2024 9:17 PM UTC
Where am I able to find "Minimum Notice" in settings?
 I am trying to avoid same day appointments but am unable to locate within Settings.  Is this option available on the free version?
Dec 10, 2024 9:20 PM UTC
Hi ​@Gene01250 - Thanks for reaching out!
Avoiding same-day appointments is available on the free plan! This is configured through the event settings under the Availability Tab. Under Date-Range you’ll find the option to change it here:
Hope this helps! Let us know if you have any other questions!
