Dec 19, 2025 3:01 PM UTC
Display availability without allowing booking.
Hello All!
I would like to display my availability without allowing booking.
I want to disable or hide the "NEXT" button booking option while still showing my schedule.
The "NEXT" button is shown after a client chooses a day on the booking calendar.
I can add CSS and PHP functions in WordPress if this helps find a solution.
Dec 21, 2025 6:37 PM UTC
Hey ​@Tom66160 -
The Calendly booking widget (iframe) doesn’t support this feature; however, you can use Calendly’s API to show your availability without allowing the invitee to book.
Specifically, you can use the “List Event Types Available Times” endpoint (https://developer.calendly.com/api-docs/6a1be82aef359-list-event-type-available-times) to display your availability on your site without allowing the invitee to book.
Tom66160Author
Dec 24, 2025 7:30 PM UTC
Thanks Calforce50652,
I had seen that already and determined it is not worth the effort.
It describes limits that makes it useless:
Date range can be no greater than 1 week (7 days).
In WordPress, I can add:
  • CSS
  • PHP
  • Embed
  • HTML
All that needs to happen is to make the “Next” button not work.
Or better yet, have it say ”Available”.
Dec 24, 2025 8:03 PM UTC
Hey ​@Tom66160 -
An alternative solution would be to use a tool like Cloakist (https://cloak.ist/calendly) to host the Calendly scheduling page. This option allows you to inject custom CSS, JS, and HTML into the scheduling page, which would allow you to disable the “Next” button / change the text.
Below is a video tutorial of how to change the Calendly scheduling page’s CSS with this option:
Tom66160Author
Dec 28, 2025 3:49 AM UTC
Thanks again Calforce50652,
Defiantly not pointing my domain name anywhere else and paying more for it 😓
Jan 19, 2026 2:23 PM UTC
Hey ​@Tom66160 -
I know this is a late reply, but I wanted to let you know that this feature is now available in Calendly Components - a tool that uses Calendly’s API to add features to the normal embed code.
Tom66160Author
Jul 8, 2026 3:16 PM UTC
I found a temporary, incomplete and mostly useless workaround for WordPress.
WordPress
I embed calendly code in Avada element on website.
I set link in element so if you click anywhere on element, containing calendar, it takes you to a intake form.
You cannot use:
  • Available time
  • Next month
  • Or any of the normal features of calendly
Its hard to believe that so few people don't care about clients being able to see availability without booking.
If a client can’t schedule on my available date I do not want them booking or filling out form.
If we can’t schedule there is no point in wasting our time.
