Dec 12, 2025 4:30 PM UTC
"stytch_block_verdict:true"
Hi Team, I want to verify what is the meaning of this message: “stytch_block_verdict:true” in a post request with 200 response.
Cameron
Employee
Employee
May 28, 2026 7:19 PM UTC
Hey ​@Johan41001 - Thanks for reaching out!
In this case, stytch_block_verdict: true means the booking request was blocked by Calendly’s security checks during the scheduling flow.
In other words, the request reached Calendly successfully, but it was prevented from being finalized because it was flagged as suspicious. It does not usually point to a formatting issue with the API request itself.
If you’re seeing this unexpectedly, the best next step is to contact Calendly Support here and include the telemetry/error ID from the response so the team can review the specific block for you.
