Solved
Find Technical Documentation for Salesforce
  • May 22, 2025
  • 2 replies
  • 134 views
I’m trying to locate what components are installed into Salesforce when adding the Calendly app is added. My client does not yet have Calendly and they want to know the field mapping. Is that something that is available?
Best answer by David
Hi ​@helen.lueck - Thanks for reaching out!
You can find the list of our Salesforce components here: https://help.calendly.com/hc/en-us/articles/14475454797079-Calendly-Salesforce-package-version-2-components#01H7GC8XFDHJFEG4B6T1D3PN35
If you’d like to dig deeper into everything we have documented for the Calendly <> Salesforce integration, you can find this here: https://help.calendly.com/hc/en-us/sections/4407255898775-Salesforce
DavidAnswer
Fantastic ​@David ! Thank you so much!!
