Help to tailor a field
Is there are way to tailor the wording in the invitee details field. e.g. we need this to say CM Name, CM Email so it prompts our team to enter the right persons details - they find it very confusing?
    Hi ​@JenGriff - Thanks for reaching out.
    At this time, there is not a way to change the default Name/Email field in your booking pages. I can get this over to our product team as feedback so hopefully we can see this changed in the future!
    In these cases, some users will explain which information to put where in the Event Description, or they’ll add additional invitee questions in the booking page.
    JenGriffAuthor
    Thx for replying, David. Adding the detail to the event description creates unnecessary busyness in the invite, so while I appreciate the work around suggestion, it isn’t ideal. We’ll make do for now, but if you could feed-back the feedback to the product team it would be great, hopefully in time this might get upweighted to allow for it to be actioned. Rgds
