Oct 12, 2026 10:24 PM UTC
Not connecting with my calendar
I am having problems with my Calendly account not connecting to my apple calendar.  I cannot link to iCloud either as it is asking for an app specific password.  This has resulted in clients not being able to book any services with me.
Oct 13, 2026 12:27 PM UTC
Hi ​@Karma83631 - Thanks for reaching out!
The app-specific password is something generated from your Apple account directly. I found an article from Apple Support that walks you through creating one!
You can read on this here: https://support.apple.com/en-us/102654
danielbrooks
Oct 15, 2026 9:13 AM UTC
One extra check that has caught out a couple of people I have helped with the Apple Calendar connection: make sure two-factor authentication is actually turned on for the Apple ID first, because the app-specific password option does not appear at all without it. When you generate the password on the Apple ID site, copy it exactly as shown and paste it into Calendly straight away - the password is only displayed once, and if you close that window you have to generate a fresh one rather than trying to reuse an old one. Also, do not use your normal Apple ID password in the Calendly password field; that almost always produces the generic could-not-connect error. If a newly generated password still fails, revoke any older Calendly passwords listed under app-specific passwords in your Apple account, generate one more, and reconnect from Calendly's calendar connections page while signed in to the same Apple ID in your browser. That clean-slate approach resolved it for us.
IT Support Technician based in Albuquerque. I help small service teams set up Calendly scheduling, routing forms, reminders and workflows.
