Parent teacher appointments. What tariff will I need?
I am a private tutor and want to set up 15 minute slots for 50 parents to make an appointment.
Which payment option do I need? I think the free option only lets me invite one person.
Will the standard tariff let me do this?
Also, will I be able to send one invite out to all of the parents at the same time?
    Hi ​@Natasha82730 - Thanks for reaching out!
    Depends how these meetings need to be setup. For example, on the free plan, you’ll have access to our one-on-one event. While you can only create one event type, you can schedule as many people as you need. So if these meetings are with one or two parents at a time, the free option will work fine! You’ll be able to create your one-on-one event, then send your link out to all parents at once.
    If you need to meet with all 50 parents simultaneously, the Standard Plan includes the Group Event which allows multiple people to pick the same time. This is usually used for webinars, tours, ect.
    Let me know if you have any other questions, but it sounds like the free plan would be just fine!
