Oct 16, 2026 2:38 PM UTC
Redirect after successful booking does not work with embedded Calendly on WordPress
Hello,
I am using Calendly Standard together with a WordPress/Elementor website.
The booking itself works correctly. A user can choose a time, complete the booking, and Calendly confirms the appointment successfully.
For the relevant event type, I have configured:
After booking → Redirect to an external site
with this URL:
https://mathematik-lernen.com/termin-bestaetigt/
The redirect URL has been saved correctly in Calendly.
The target page exists in WordPress and is publicly accessible.
However, after a successful booking, Calendly still remains on its own confirmation page and does not redirect to the external URL.
This happens both on iPad and Mac/Desktop.
Could you please clarify the official recommended solution for this setup?
  • Does external redirect work reliably with an embedded Calendly booking form?
  • Does the redirect need to be configured separately for each event type?
  • Are there any restrictions with WordPress/Elementor embeds?
  • Is there a specific embed method required for redirect-after-booking to work?
  • If redirect is not supported in this configuration, what is Calendly’s recommended official method for tracking a successful booking in GA4 / Google Ads?
We would appreciate the simplest and most reliable solution.
Thank you.
Oct 18, 2026 2:12 AM UTC
Hi Marcel, I ran into the same thing when building a Calendly Embed for Wordpress. Two quick checks first:
  1. The redirect is set per event type. If your page embeds your main Calendly link (calendly.com/yourname) instead of the event itself, check that the event people actually book has the redirect turned on.
  2. Open the exact link from your embed code in a private window and make a test booking. If the redirect works there but not on your site, it's the embed, not the setting.
The fix that always works, and also answers your GA4 question: the Calendly embed tells your page when someone books (it sends a calendly.event_scheduled message). Your page can listen for it and do the redirect and the GA4 event itself.
In Elementor, add an HTML widget on the same page (or put it in the footer with a code snippets plugin):
<script>
window.addEventListener('message', function (e) {
if (e.origin !== 'https://calendly.com' || !e.data || e.data.event !== 'calendly.event_scheduled') return;
var done = false;
var go = function () {
if (done) return;
done = true;
window.location.href = 'https://mathematik-lernen.com/termin-bestaetigt/';
if (typeof gtag === 'function') {
gtag('event', 'calendly_booking', { event_callback: go });
setTimeout(go, 1500);
} else {
go();
</script>
Then mark calendly_booking as a key event in GA4 and import it into Google Ads as a conversion. With Tag Manager instead of gtag, push { event: 'calendly_booking' } to the dataLayer and use a Custom Event trigger on that name.
