Feb 13, 2026 7:17 PM UTC
Solved
Required field
How do I make it so that when someone books an appointment, they have to enter their phone number? There's only an option to enter the phone number, and I want it to be a required field. Do they need to be contacts for it to be an auto-filled field?
Thanks!
DavidAnswer
Feb 13, 2026 7:54 PM UTC
Hi ​@Eduard78237 - Thanks for reaching out.
At this time, the text reminder field cannot be marked as required. This is because our texting service requires consent to be given from the user to be sent a reminder text.
However, if you’re just wanting to collect their phone number for later use - You can use the invitee form setting and make the question required there:
This won’t send them any reminders, but it will collect the information for you.
DavidAnswer
Feb 16, 2026 8:34 AM UTC
Thanks! It helped me :)
