Oct 1, 2026 7:25 AM UTC
Salesforce integration issue, even after it was claimed to be fixed
Hi,
I reported the issue of not being able to reconnect Calendly to Salesforce on the 25th. On the 26th I got a response saying a temp fix had been deployed.
This fix did not work for us, so we were asked to wait for a final fix that cam later the same day. This fix did not work either, and we are still not able to reconnect the integration. I reported this as a response in the same day. Since then, I’ve been in a loop where I get responses from your support, but they just say they are waiting for a response from the Engeneering department.
I would appreciate a confirmation that this is still being looked at, as we’re closing up on one week of downtime, and this is impacting our business.
Oct 1, 2026 2:02 PM UTC
Hi ​@Sjur Mathisen TeamRobin - Thanks for reaching out on this, sorry this has been going on for so long!
Firstly, in case it hasn’t been linked yet, we do have a way to import missing data into SF be following the article here: How to import missing data from Calendly into Salesforce | Calendly Help
Secondly, It looks like our engineering team is still working away on this. but its something they’re taking on a case-by-case basis. Rest assured, we will find a fix! As soon as we hear anything we’ll update you ASAP via email.
Oct 1, 2026 4:52 PM UTC
​@David thanks for clairifying it is done on a case-by-case basis, as that explains why it takes time:)
Oct 2, 2026 3:27 AM UTC
hi ​@David can I report the same issue here? we have intermittent disconnected issues since last weekend, and the connection usually drops off after a few hours of reconnect. Should I provide any detail for you to raise a case?
Oct 2, 2026 1:34 PM UTC
Hi ​@Zenyum61030 - Thanks for reaching out on this!
These are best sent to our Support team to handle. You can use the chatbot or email support@calendly.com
Just include some details about your instance, whats going on and any errors that you might be seeing.
They’ll be able to assist further from there!
Oct 5, 2026 3:48 AM UTC
hi ​@David I raised the case through support email, but previously I already used the chatbot to trouble shoot and the issue persisted. can we have a real person to assist us? case # 4043764, thanks
Oct 29, 2026 11:45 AM UTC
We’re currently dealing with this issue. It’s been about a month we’ve been dealing with it and still no resolution. Disconnected 3x in the past 3 days. This is not good for our business as we have 37 seats and were about to purchase another 27. I can’t even imagine every single one of them reaching out to me to make a complaint when it disconnects and then merging their data every single time.
We need a permanent solution to this.
Nov 2, 2026 1:35 AM UTC
Adding our experience here. Our Calendly Salesforce integration has silently disconnected 7 times in the past two weeks, and each reconnect lasts less time than the one before. There's never any notification. We only find out when bookings stop showing up in Salesforce.
Our Salesforce logs show every Calendly token refresh succeeding right up until Calendly stops calling, with no failed logins and no revoked tokens. We've done full disconnects and reconnects, and even switched to a different admin user. Nothing helps. Support has blamed a "stale" connection and then a Salesforce outage, but neither matches our timeline.
Every disconnect means more manual data cleanup for us. With multiple customers here reporting the same thing, it's hard to accept that this is being handled "case by case". And the official "How to import missing data from Calendly into Salesforce" article is garbage. If your org has activated any Calendly flow automation, do not follow that article.
My personal guess: this goes back to Salesforce's push from Connected Apps to External Client Apps. Our September disconnect was blamed on a Salesforce update that mishandled Calendly's connected app, and things have been unstable ever since. I suspect Calendly's integration was never properly adapted to these changes, and we're all paying the price.
