Feb 20, 2026 3:48 PM UTC
Same hours but Place diffrent
Afternnon
I would like create some event on sunday
It s always the sunday morning but it s 3 plces differents
I go in Avaibility in schedule
I put the time always the same 9H30/11H30
I create  3 events
I create for each place a event
in Schedules availability I select 1 event and put the day available
I do that for the 3 events
When I look the link of each event all the dates are available for the same place
I would like that the place change depending of the date choose in the schedule
Feb 20, 2026 9:25 PM UTC
Hi ​@Sandrine52685 - Thanks for reaching out.
There isn’t a way to have the event change based on what date is selected - Instead, with the three events, you would need to change the availability within the event itself. You can do this here:
Once you change it here, it will only change it for this event, not effect any of the others.
